MMOexp-Lineage 2M: Top Free-to-Play Class Picks — Max Efficiency Without Whaling
Nevinchnabel
1er Frischling
Beitrag von Nevinchnabel »
Lineage 2M continues to be one of the most competitive MMORPGs in the mobile and PC space, and class choice plays a huge role in both PvE grinding efficiency and PvP dominance.
Many players find themselves stuck wondering whether to stick with their current class or switch to something stronger, especially after updates that shift the meta.
This guide breaks down the current PvE and PvP class tier lists, divided into Tier 1, Tier 2, and Tier 3, based on in-game performance, skill efficiency, and overall value for free-to-play, low spenders, and heavy spenders alike.
PvE Tier List-Best Classes for Grinding L2M Diamonds
When it comes to PvE, efficiency is everything. A class's ability to farm experience and loot quickly determines how fast you progress, and some jobs simply outperform others because of their area-of-effect skills and mana management.
Tier 1 PvE-ORP (Oracle/Prophet)
The ORP is without question the best class for PvE farming right now. Its strength comes from skills like Aura Flash, which when paired with Divine Spark, becomes an AoE nuke with a 0.5-second cooldown. Even better, it only costs around 40 MP, making it extremely mana-efficient.
What makes ORP shine is its scaling potential:
With just Aura Flash, it already outperforms most classes.
Add Aura Blast, which converts aura bolts into AoE, and you now have two strong area skills.
For high spenders who unlock Judgment, ORP gains a third AoE, making it unmatched in farming.
Tests show ORP farming 20-25% faster than Mage or Dual Blade classes with the same gear. Free-to-play players love it because it doesn't demand heavy investment, while whales can turn it into an unstoppable farming machine.
Tier 2 PvE-Dual Blade & Mage
Dual Blade: Known for its Dance of Fury buff, Dual Blade boosts attack speed by 20%, casting speed by 20%, and movement speed by 15%. Even when switching weapons, part of the buff stays active, making it a versatile pick. Its Triple Slash skill provides decent AoE damage, and with Sonic Blaster, it gains another strong PvE tool. Dual Blade is excellent in both solo grinding and party play.
Mage: Mages are strong AoE grinders thanks to skills like Tempest, Snowstorm, and Windstride. Their long range makes farming safer, especially in contested zones. However, they require significant investment in rare skillbooks like Restore Casting, which resets cooldowns instantly. For free-to-play players, Mage is less recommended, but for mid- to high-spenders, it becomes one of the best PvE classes.
Tier 3 PvE-Assassin
Assassins rank lower in PvE because their AoE is more conditional. Skills like Shadow Blade can create clones that deal area damage, and Venom provides a strong line-based AoE.
They're faster than Archers for grinding, but compared to ORP or Mage, their efficiency falls behind. Still, for players who enjoy high mobility and burst potential, Assassin can be fun to farm with.
PvP Tier List-Best Classes for Battles
PvP in Lineage 2M is brutal. With large-scale 50v50 wars, small clan skirmishes, and one-on-one duels, the meta shifts depending on context. Here's how classes rank for competitive play:
Tier 1 PvP-Sword
The Sword class dominates PvP thanks to its stun potential. Skills like Double Shock can lock enemies down for up to 9 seconds, which is devastating in both duels and group fights.
Highlights:
Extremely effective in 1v1 scenarios.
Devastating in small group fights when chaining stuns.
Can switch between Sword and Dual Blade to adapt playstyle.
The downside is that Sword is terrible for PvE grinding due to long skill cooldowns and limited AoE. Many Sword mains grind using Dual Blade builds before switching back to Sword for PvP.
Tier 2 PvP-Dual Blade & Assassin
Dual Blade: A powerhouse in PvP due to skills like Sonic Slash (0.5s cooldown) and Triple Slash, which provide fast, consistent damage. The Dance of Fury buff is also huge in team fights, boosting allies' stats. Dual Blade players can sustain themselves with lifesteal and critical buffs, making them a must-have in clan wars.
Assassin: The king of burst damage. Coming out of Hide, Assassins can delete squishier enemies with devastating combos. With skills like Venom, their sustained DPS also remains strong. However, in large-scale PvP, assassins struggle because getting close to targets often results in being focused down quickly. They shine best in duels and small-scale PvP.
Tier 3 PvP-Mage
Mages drop to Tier 3 in PvP, but they bring immense crowd control utility:
Tempest reduces defense.
Cancellation removes buffs and prevents rebuffing temporarily.
Confusion and Darkness debuff enemies, reducing mobility and vision.While their burst damage isn't as high as Assassin or Dual Blade, their CC makes them invaluable in large-scale fights. A well-timed Meteor can still change the tide of a battle. For free-to-play players, Mage works better as a semi-support PvP role, providing debuffs from long range.
Support Classes in PvP-The Hidden MVPs
No PvP tier list is complete without mentioning support classes like ORP in a healing role. With access to Arc Shield, they reduce incoming damage for allies by 50% for 25 seconds, which can completely turn fights.
Support ORP skills:
Group Heal: Keeps entire parties alive.
Cure: Removes debuffs like blindness or poison.
Arc Shield: Mandatory in large-scale PvP, especially for clan wars.
For competitive guilds, bringing at least one ORP with Arc Shield is non-negotiable. In fact, many strategies revolve around protecting Arc Shield casters while they keep the frontline alive.
Final Thoughts-Which Class Should You Pick?
Choosing a class in Lineage 2M ultimately comes down to your goals and budget:
Free-to-play players: Stick with ORP for PvE and Sword or Dual Blade for PvP. They offer the best efficiency without requiring heavy investment.
Low to mid spenders: Dual Blade provides balance in both PvE and PvP, while Mage becomes viable with access to premium skillbooks.
Heavy spenders (Sultans): You can maximize Mage or ORP builds with rare skills like Restore Casting and Judgment, making them absolute endgame monsters.
In short: Lineage 2M Diamonds
Best PvE farmer: ORP
Best PvP duelist: Assassin
Best PvP team fighter: Sword
Best overall hybrid: Dual Blade
Best support: ORP (Arc Shield build)
No matter what class you choose, remember that Lineage 2M is as much about teamwork as raw power. Building around party synergies-such as combining CC-heavy mages with sustain-heavy ORPs-can often matter more than individual tier rankings.
